In Revit 2023, you can publish sets and latest version of Revit model to ABC Pro through the following steps:-
Check the publish setting of the views and sheets you want to publish to the Cloud
Then syncing the changes with the Central Model
Go to the Revit interface Home and throughout Autodesk Docs , check you right Account and Right Project and Right Model Location.
You can navigate using shortcut Ctrl+D
Click on the 3 dots and choose Publish Latest
You can also publish from the Desigh Collaboration Module as the following steps
go to your right project on the ACC and go to Design Collaboration Module
Make the team current in this Demo, I want to Publish model to STR Folder so that I click to STR
Then Click Publish Latest
And also you can Schedule Publish at time you want
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
