How to Count Blocks in AutoCAD
We can find the number of blocks using different methods in the autocad environment such as Bcount command, Select Similar , qselect and etc. In this article, we will see how to find the number of objects with the COUNTLIST command.
With the COUNTLIST command, we can list the number of objects in the active document and insert a table with the specified blocks. You can export this table as csv file.
You can access the COUNTLIST command from the view tab > Palette Panel.
Count list commandCount list command
This command opens the Count palette to display and manage the counted blocks. The Count palette allows you to view the blocks on the current drawing and insert a table with the specified blocks.
Count PaletteCount Palette
When you select one of the listed objects, the selected object is highlighted on graphic screen (Model Screen )
The Count palette displays count details including the error report, if any. The report lists the count errors such as overlapping, exploded, or renamed objects. You can view error details and highlight (Red) problems on graphic window when click the error icon on Count palette.
When you select the error message, it will focus on the object with the problem.
You can generate block count list table with Generate Table generate Table.png
To create the table, do the following:
  • Click generate table icon on palette
  • You can choose blocks name that you want
  • Click insert button and you can insert the table into dwg file
Counting objects from a part of a drawing like a selection or an area in a specified viewport is not supported. The following objects are also not supported and excluded from the count:
  • Text
  • Hatches
  • 3D objects such as solids and meshes
  • Images
  • OLE objects
  • Lights and cameras
  • Non-DWG underlays
  • Geographic data
  • Coordination models
  • Point clouds
  • Attribute definitions
  • External references
  • Construction lines (xlines)
  • Rays
Note: Only the visible blocks in the model space are displayed in the Count palette.
When the count palette is opened, the count toolbar will also open.
When you're in an active count, the Count toolbar displays at the top of the drawing area.
2 Comments
MatiasWendt
the evolution of this command will be very useful in the day-to-day of each user, just get used to exploring this and other new tools..
T.Ferreira
Excellent, thanks for sharing!
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
