Note: This article is written and published in Ukrainian and is a translated version of the original published here.
The update focuses not only on fixing bugs from previous versions, but also on the introduction of AI assistants, deeper integration with the Forma cloud environment, and significant improvements for tracing and drainage.
Below, I have collected the most interesting innovations from the point of view of a design engineer and analyzed how they work in practice.
1. Autodesk Assistant (Tech Preview) – Your Personal AI Assistant
It's your personal AI assistant with contextual understanding. Autodesk Assistant now has AI chat and query-based workflows.
Artificial intelligence continues to be deeply integrated into CAD. Assistant now supports Model Context Protocol (MCP). It accesses a database of objects, reads metadata, geometric parameters, and relationships between elements.
Now it's not just a smart Autodesk help search ribbon, but a full-fledged AI chat and workflows driven by text prompts.
This means that the assistant does not just look for information in the help, but "sees" your current drawing. Interestingly, the AI assistant can change the display style of objects at your request. For example, tracks or surfaces.
Example of use: You are working on a large-scale master plan. Instead of searching for or counting the lengths of alignments, or the area of hatches, or which layer elements are on, you write your requests in the chat. The assistant analyzes the objects of the model and displays the necessary information. This saves a lot of time.
Previously, to collect basic statistics, you had to create specifications, use Data Extraction, or endlessly click on objects with the Properties window open. Now you delegate this routine to an assistant.
The implementation of MCP turns Autodesk Assistant into an active participant in the design. By analyzing model objects and displaying the necessary information in a matter of seconds, it significantly saves time at the stages of verification, model audit, and final design. This allows the engineer to focus on complex tasks and the development of automation logic, leaving routine data acquisition to artificial intelligence.
See more details about this new feature below at the link –
Autodesk Civil 3D 2027 Help | Autodesk Assistant | Autodesk
Note: The new features of Autodesk Assistant are currently available as a preview version and will be gradually improved. Results may not be accurate at this time. So, check the data.
- Horizontal Regression Analysis with Machine Learning
The tool for creating the axis of the track using the method of least squares (Best Fit) has received a powerful upgrade (appeared in version 2026.1). An alternative algorithm based on machine learning (ML Based Detection) has appeared to recognize trace elements from a point cloud or geodetic survey. Also added a non-modal window with a preview right in the model space.
- Example of use: When reconstructing an existing route, the traditional algorithm can "break" on difficult cases of the route and give errors. You switch to ML Based Detection, and the program approximates the geometry much more accurately. With the non-modal mode, you edit the trace with the grips, and the curvature plots are updated in real time without having to constantly close and open the dialog box.
The reconstruction of roads and railways has always been a challenge due to the need to accurately fit the design axis into the existing geometry. In Civil 3D 2027, the Horizontal Regression Analysis (HRA) tool received a fundamental update that makes the regression process transparent and interactive.
The main innovations of the tool:
Live Preview: Now the regression trace is created directly in the model even before the final confirmation. It is dynamically linked to the curvature graph and segment tables. Any change in the algorithm parameters instantly updates the geometry on the screen. This allows you to visually assess the quality of the incorporation of clotoids and radii on the fly.
Non-modal mode of operation: No more closing the HRA dialog box to zoom in, check the coordinates of a specific point, or switch between drawings. The tool runs in the background, allowing you to fully interact with the model space.
Machine Learning (ML) Integration: In addition to the classical mathematical algorithm, it is now possible to switch to the machine learning model.
What is it for: Classical algorithms sometimes fail on "noisy" survey data or with complex combinations of inverse curves. The ML model offers an alternative solution, based on pre-trained engineering geometry patterns.
Important: The model works locally, does not use your confidential data for additional training, and guarantees the stability of the result.
Improved Sync and Navigation: Selecting a row in a datasheet or a segment in a curvature graph automatically highlights the corresponding area in the drawing. Added Zoom To functions through the context menu, which is critical for objects tens of kilometers long.
Practical Use Example:
Imagine working with a point cloud after laser scanning a train track. The data may be scattered or have significant deviations due to ballast wear.
You run HRA and see that the classical method creates gaps in geometry.
Thanks to the non-modal window, you zoom in on the problem area without interrupting the analysis.
Switch to Machine Learning detection with one click. The system automatically recalculates the axis, eliminating gaps and ensuring smoothness of tangents.
All offsets are calculated strictly perpendicular to the new objects, and unified stationing ensures that the data in the tables and on the curvature graph are identical to the millimeter.
Engineering conclusion: The updated HRA turns regression from a "black box" into an interactive design tool. The engineer now monitors every radius and transition curve in real time, obtaining a mathematically sound model in minutes.
But from a meticulous and professional point of view, this functionality still needs to be improved, namely in the direction of connecting route elements (straights, curves, transition curves), as well as paying attention to the creation of complex curves, and so on.
Autodesk Civil 3D 2027 Help | Horizontal Regression Analysis | Autodesk
- Daylight Feature Line (Tech Preview)
Finally, there is automation of terrain access without the need to create heavy Grading objects, which often overload the model. This tool creates a Daylight structural line based on the specified criteria.
Feature Lines have always been the "skeleton" of vertical planning in Civil 3D. In version 2027, the developers took a step towards users who are tired of the instability of Grading Groups by introducing a new type of object — Daylight Feature Line.
For years, engineers have struggled with the fragility of grading objects (Grading). In the 2027 version, Autodesk has bet on Daylight Feature Lines. This is a fundamental change: instead of forcing the user to create cumbersome topological designs, the program provides a lightweight tool that automates complex geometric constructions. The improved logic of Undo/Redo and accelerated operations with feature lines without pads indicate that developers have finally heard the requests of the professional community regarding performance on large facilities.
- Example of use: You need to quickly place a construction site on difficult terrain for a preliminary estimate of earthwork volumes. Instead of constructing grading groups, you select a structural line of the site boundary, specify slope criteria (for example, 1:1.5 for excavation), and instantly get a line of intersection with the existing surface.
Imagine a situation: you are preparing a pre-project proposal for the construction of a solar power plant on 50 hectares. The relief is difficult—foothills with constant changes in slopes. The customer asks to produce earthwork volumes for 20 inverter substation layout options in one night.
Previously, you would create Grading Groups. But with so many objects, Civil 3D could begin to "crumble": each relocation of a substation caused a recalculation of the entire group, and a fatal error when undoing an action could lead to the loss of site geometry.
4. Cloud Network Directories in Forma Data Management
One of the biggest pains of BIM managers in large teams has always been the synchronization of pipe catalogs. Previously, it was necessary to use network drives or manually copy .apc and .xml files. In Civil 3D 2027, this problem is solved thanks to Forma Data Management.
The only source of truth: Catalogs of non-pressure and pressure pipes can now be stored directly in the Forma cloud project.
Auto Sync: As soon as the BIM manager makes changes to the catalog (adds a new diameter or material), these updates are automatically synchronized with all designers working on the project.
Cross-project access: You can link to a catalog from another project (if you have access rights), which allows you to create enterprise standards libraries directly in the cloud.
Example of use: Your company is switching to using pipes from a new manufacturer for a specific region. You update a directory in Forma, and all 15 engineers in the department instantly see new items in their Part Lists without any manual reloading of configuration files.
5. Bridge detailing and improved clothoid tessellation
In addition to major system updates, Civil 3D 2027 has received two important technical improvements affecting fidelity and navigation in the model.
Hierarchy of bridges in Prospector
Previously, bridges imported from InfraWorks were displayed in the Prospector window as a single, monolithic object. This made it difficult to work with individual elements.
What has changed: The full hierarchy is now available in the Navigator. You can expand the Bridge object tree and see all its components: supports, beams, crossbars, piles, and decking. This allows you to quickly find the desired element and manage its properties.
Unified tessellation of transition curves
The accuracy of displaying clotoids (transition curves) has reached a new tier.
Down with system variables: It is no longer necessary to remember the
AECCENHANCEDSPIRALSAMPLINGvariable. In version 2027, the improved method became the default standard. -
Result: Smoother rendering and higher fidelity when calculating points on complex rail and road curves. The program automatically uses the optimal sampling step to reproduce geometry as accurately as possible.
Summary
The 2027 release shows Autodesk's clear vector: stability, cloud, and AI. This is the version where the tools finally begin to "understand" the engineer.
The release marks the transition from the concept of a "sophisticated graphics editor" to an "intelligent engineering environment". If earlier the program only executed commands, now it begins to understand the context and intentions of the designer.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
