You get to choose, you get to pick, and you get to decide!
Select the elements that you would like to have in a selection set.
Next, choose to Save that.
Name the set.
The selection will be in Filters.
Go to any View Template and add the Filter.
Choose your Filter Settings.
Check out your filter Selection Set!
Just a note here, I really wanted this to work if I chose a linked file, but alas, it does not. There are too many subsets like the link's walls, doors, and windows that have to be done separately.
#CADMama #AutodeskCommunity #AutodeskExpertElite #Revit #Filters
Donnia Tabor-Hanson, aka CADMama
Revit Family Counselor
Twitter @DonniaTH
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
