Large assembly Strategies in Autodesk Inventor - Part 3
Introduction to Content Centre in Autodesk Inventor
Inventor’s Content Centre is a built-in library of standard components/parts. The parts/components include fasteners, shaft components, structural shapes, features, sheet metal parts (studs, nuts, standoffs), tubes, and pipes. These components/parts exercise strict adherence to international standards. The standards available within this library include ISO, DIN, ANSI, JIS, GB, GOST, BSI and Parker. It’s worth noting that the library is continuously updated with successive new Inventor releases, if there are updates to existing standards or creation of newer ones, ensuring compliance and alignment with the latest global industry standards.
You can think of the Content Centre as a database of part files whose design geometry is defined with parameters (which they are). The parameters are then neatly organised and stored in a structured tabular format, in rows and columns, in the database. This draws similarities to how data is organised in an Excel spreadsheet. Taking a bolt as an example, each row could potentially represent a unique standard, with columns potentially defining properties of the specific part, such as size, thread type, etc. You get the drill.
Loading & Unloading Content Centre Libraries To & From a Project
To load a standard into your design is to basically add the corresponding Content Centre library to the active project. This process ensures that ONLY standard parts/components associated with that particular library are available for use within the active project.
Unloading a standard means removing its Content Centre library from the active project, which restricts access to the associated standard parts/components. This streamlines your design process by limiting available content to only the relevant standards needed for a specific project. Reducing errors and clutter in return.
2024 Final of Final PNG2024 Final of Final PNG
Why is this Essential?
Cumulatively, the Content Centre library approximately contains over 1 million variations of standard components/parts (no, that is not a typo!). This, therefore, means Inventor will take more time to search and index this data in the library as you place the part/component into your assembly. Remember, the part only exists as a part file definition in the database, and not as a solid 3D geometry.
The component’s/part’s geometry is computed at the instance it is placed in the assembly based on the input data you furnish to Inventor via the dialog box. More search time means more seconds wasted waiting for Inventor to resolve your query based on the input data you will have provided, and this can quickly compound when working with large assemblies. Also, realistically, you won’t need all of these 1M+ variations of parts/components in your designs. This is why it’s essential to load only the standards relevant for a particular design project and unload/remove that which is not required.
Steps to Unload & Load Content Centre Libraries to an Active Project:
To load a particular library into an active project:
  • Launch Inventor, and you are greeted with the default Home Page interface. No files should be open at this point. If there are active/open Inventor file(s), make sure they are closed, especially if you have configured Inventor to open a specific part or template when fired.
  • Navigate to the Project editor dialog box and confirm that the target project is active.
Project Editor Dialog BoxProject Editor Dialog Box
  • In the lower right corner of this dialog, click the Configure Content Centre Libraries button. You are then greeted with the Configure Libraries dialogue box.
Configure Content Centre Libraries Button on the Lower RightConfigure Content Centre Libraries Button on the Lower Right
  • On the Name column of this dialog, identify the required standard necessary for your target project and check and uncheck where necessary in the corresponding In Use Column. Click OK when done for changes to take effect and to consequently close this dialog box.
Configure Libraries Dialog BoxConfigure Libraries Dialog Box
  • This is how you load and unload specific libraries to and from a target project.
  • Video reference below:
Placing Configured Content Centre Files into Your Design
Once you are through with the above configuration, you can finally place the required Content Centre files into your design easily.
  • Navigate to the Assemble tab, locate  Component panel, and click the arrow icon under the Place tool. This reveals a dropdown where you can access Place from Content Centre.
Place from Content Centre  PNGPlace from Content Centre PNG
  • Click Place from Content Centre. You are then greeted with the Place from Content Centre dialog box.  From here, locate the part you want to place in your assembly.  Notice that the components are grouped into unique categories in the Category View area on the left pane of this dialog box.
Place from Content Centre Dialog BoxPlace from Content Centre Dialog Box
Advantages
  • It facilitates restricted access to specific standards and parts required for a given project, preventing the risk of errors caused by accessing and using standards from an unauthorised or different library.
  • It is time-saving because authorised components from a given standard are “ready-made” and can easily be accessed when needed for a specific design project, reducing the need to model parts/components from scratch.
  • Facilitates compliance with standards, especially for regions of the world that only use a specific standard within the content centre library. For instance, if a design firm operates in a country that only uses the ISO standard, it can restrict access to other standards, thereby enforcing compliance with regulatory laws.
  • There’s an aspect of flexibility as you can load and unload specific libraries to suit different clientele around the world. You are not limited to a single standard if the regulations in your country permit it.
  • Improved performance. You may be asking, how? When you unload Content Centre libraries you don’t need for a given project, Inventor narrows down the search tree/path from over 1 million component variations available in the library to just a few thousands or hundreds. This reduces search and index time and frees up system memory for other design-intensive tasks. This can be quite useful when you have limited system resources. It’s the little things.
  • Creating and installing/loading custom Content Centre libraries that only you or your company uses/needs reduces clutter and saves storage space, whether on individual machines or on network storage disks.
Disadvantages
  • Unloading Content Centre libraries you don’t need for a given project might take a few seconds to set up. However, this might not make sense for a single, simple one-off project that might only need about three or four parts from the Content centre.
  • Setting up a custom Content Centre library from the default Content Centre library for you or your design team might take a few minutes. However, the benefits of this action will pay off in the long run.
Note:
  • From the discussion above, you can deduce that ONLY installed content centre libraries are available for use in your assemblies when you use the “Place from Content Centre” tool. Navigate to the Component panel of the Assemble tab to access “Place from Content Centre” tool.
  • Inventor allows you to create custom libraries based on the available standards for you or your team/company. When shared over a network, these libraries can be useful in collaborative environments, ensuring that design teams are reading from the same page.
  • Inventor’s Content Centre libraries are read-only. This means you can not modify them. To make any kind of modifications or alterations, you will need to create a custom content centre library and make such modifications from there.
  • Throughout this blog, Default Content Centre Library and Standard Content Centre Library have been used interchangeably.
A big thank you to @michaelrythomas  for providing me with the screenshots used in this blog.
See you around!
Ends.
1 Comment
