We need the ability to change the glyph size on feature lines. It's currently some arbitrary size that's too small and is relative to screen size. When the feature line is selected the base AutoCAD grips show up, covering up the feature line glyph. This makes it extremely frustrating to see what point you're working on.
You can barely see the glyph over the second node of the feature line due to the AutoCAD grip. The grip size can be shrunk down, but then it makes it much harder to see the grips. The best solution would be to allow feature line glyphs to be sized base on user settings. At a minimum at least increase the glyph size to something that is larger than the AutoCAD grips.
