How do I turn off the warning CIV3D puts in my drawing when a alignment doesn't meet certain criteria? Its shaped like a triangle with an exclamation point inside of it.
Solved by ToddRogers-WPM. Go to Solution.
Go to your Alignment Properties, on the Design Criteria tab, uncheck Check for tangency between elements.
Or what Jeff_M says...turn off the Warning Symbol in your Alignment style.
Go into the style and turn off the layer and if you want/don't want them printed it's in Options
The above steps did not work for me.
To turn off the red triangle at the end of the alignment.
Choose Alignment properties>summary tab>+Marker> choose <none>
This post isn't about the red triangle at the end of an alignment. It's about the warning symbols.
If you read a few comments above you'll see a question asked "How do you turn off a triangle with a dot in center on your alignment?" asked and answered!
