warning alert for alignments
How do I turn off the warning CIV3D puts in my drawing when a alignment doesn't meet certain criteria? Its shaped like a triangle with an exclamation point inside of it.
Replies (12)
ToddRogers-WPM
Go to your Alignment Properties, on the Design Criteria tab, uncheck Check for tangency between elements.
Todd Rogers
Jeff_M
Alignment Style Display tab
ToddRogers-WPM
Or what Jeff_M says...turn off the Warning Symbol in your Alignment style.
Todd Rogers
neilyj666
Go into the style and turn off the layer and if you want/don't want them printed it's in Options
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
thanks everybody, big help
How do you turn off a triangle with a dot in center on your alignment?
ToddRogers-WPM
The answer is above as Solved.
Todd Rogers
Thanks!!!
kayci.reynolds
Community Visitor
Community Visitor
The above steps did not work for me.
To turn off the red triangle at the end of the alignment.
Choose Alignment properties>summary tab>+Marker> choose <none> Triangle with alignment.JPG
ToddRogers-WPM
This post isn't about the red triangle at the end of an alignment. It's about the warning symbols.
Todd Rogers
kayci.reynolds
Community Visitor
Community Visitor
If you read a few comments above you'll see a question asked "How do you turn off a triangle with a dot in center on your alignment?" asked and answered!
ToddRogers-WPM
Gotcha.
Todd Rogers
