Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
warning alert for alignments
12 REPLIES 12
Message 1 of 13
19009 Views, 12 Replies
How do I turn off the warning CIV3D puts in my drawing when a alignment doesn't meet certain criteria? Its shaped like a triangle with an exclamation point inside of it.
12 REPLIES 12
Message 2 of 13
ToddRogers-WPM
Go to your Alignment Properties, on the Design Criteria tab, uncheck Check for tangency between elements.
Todd Rogers
Message 3 of 13
Jeff_M
Alignment Style Display tab
Message 4 of 13
ToddRogers-WPM
Or what Jeff_M says...turn off the Warning Symbol in your Alignment style.
Todd Rogers
Message 5 of 13
neilyj666
Go into the style and turn off the layer and if you want/don't want them printed it's in Options
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 13
in reply to: neilyj666
thanks everybody, big help
Message 7 of 13
in reply to: ToddRogers-WPM
How do you turn off a triangle with a dot in center on your alignment?
Message 8 of 13
ToddRogers-WPM
The answer is above as Solved.
Todd Rogers
Message 9 of 13
Thanks!!!
Message 10 of 13
kayci.reynolds
The above steps did not work for me.
To turn off the red triangle at the end of the alignment.
Choose Alignment properties>summary tab>+Marker> choose <none> Triangle with alignment.JPG
Message 11 of 13
ToddRogers-WPM
This post isn't about the red triangle at the end of an alignment. It's about the warning symbols.
Todd Rogers
Message 12 of 13
If you read a few comments above you'll see a question asked "How do you turn off a triangle with a dot in center on your alignment?" asked and answered!
Message 13 of 13
ToddRogers-WPM
Gotcha.
Todd Rogers
Rail Community
