Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
varying slope assembly
9 REPLIES 9
Message 1 of 10
1348 Views, 9 Replies
hello
here is the pkt zip file
please help me correct that wrong pkt file
thank you so much
i want that kind of varying slope assembly.but i also have only one surface layer.
so i have to try subassembly composer but i dun know about programming and now i am in trouble
9 REPLIES 9
Message 2 of 10
KMercier_C3D
Can you answer some questions about your subassembly?
  1. Can you explain how the 72.0 is determined in your image?
  2. Would the attachment point be at the bottom left corner (next to the 1700 in the image) or at the upper left corner (next to the 76.2 in the image)?
  3. Where is the target surface in your image? Up above the 1:1.2? What happens if the target surface is in different locations?
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Message 3 of 10
in reply to: KMercier_C3D
sorry my reply was late
i was wrong. i created a subassembly composer but the link is the problem. the gaps are found
please check my pkt file.
thank u so much 🙂
Message 4 of 10
KMercier_C3D
For that pkt file, are your codes behaving properly? I would try putting a comma between every code for all points and links.
Pronouns: She/Her
Message 5 of 10
thank u so much for your reply
yes. the problem is the codes points and links
to create polyline from corridor,i have to click the outside of the corridor in one click but it was not able to click.
may be the way i talk is hard to understand.
the corridor (Daylight Bench) was able to be turned into one polyline
but the corridor i created was not able to be turned into one polyline
please tell me the problem.
thank u so much
i attached the picture.
Message 6 of 10
here is the attached file
Message 7 of 10
KMercier_C3D
In your Corridor Properties, on the Feature Lines tab, what options do you currently have selected for Branching, and do you have the "Connect extra points" selected?
Pronouns: She/Her
Tags (2)
Message 8 of 10
thank you very much for your reply
as u told,i made the feature line settings
but the one thing is that the outside of the corridor was not able to be connected.
i want to make it connected. may be the problem is the subassembly code settings or desicion formula?
please let me know.
thank you very much.
i attached the file data.
Message 9 of 10
KMercier_C3D
In SAC, do you have a point code that is consistent at the daylight point for all of your Decisions branches?
Pronouns: She/Her
Message 10 of 10
thank you  so much for ur reply
i do not understand what you want to mean
Rail Community
