hello
here is the pkt zip file
please help me correct that wrong pkt file
thank you so much
i want that kind of varying slope assembly.but i also have only one surface layer.
so i have to try subassembly composer but i dun know about programming and now i am in trouble
Can you answer some questions about your subassembly?
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
sorry my reply was late
i was wrong. i created a subassembly composer but the link is the problem. the gaps are found
please check my pkt file.
thank u so much 🙂
For that pkt file, are your codes behaving properly? I would try putting a comma between every code for all points and links.
Pronouns: She/Her
thank u so much for your reply
yes. the problem is the codes points and links
to create polyline from corridor,i have to click the outside of the corridor in one click but it was not able to click.
may be the way i talk is hard to understand.
the corridor (Daylight Bench) was able to be turned into one polyline
but the corridor i created was not able to be turned into one polyline
please tell me the problem.
thank u so much
i attached the picture.
In your Corridor Properties, on the Feature Lines tab, what options do you currently have selected for Branching, and do you have the "Connect extra points" selected?
Pronouns: She/Her
thank you very much for your reply
as u told,i made the feature line settings
but the one thing is that the outside of the corridor was not able to be connected.
i want to make it connected. may be the problem is the subassembly code settings or desicion formula?
please let me know.
thank you very much.
i attached the file data.
In SAC, do you have a point code that is consistent at the daylight point for all of your Decisions branches?
Pronouns: She/Her
