Civil 3D Forum
Subassembly not getting attached to the right side of the Assembly
5 REPLIES 5
485 Views, 5 Replies
I had made a subassembly through the subassembly composer and when I try to attach the composed subassembly to the right side of my assembly baseline it doesn't fit. I can't even find the side in property dialog box. But when the same subassembly is used in my friend's computer am able to find the side of attachment
PFA
In one figure under the Parameter you can find the "side" parameter displayed and in another one it is not present and hence I am unable to attach the subassembly to the right side
5 REPLIES 5
jroot
In creating the subassembly did you assign a LEFT or RIGHT as the default value for the Side parameter? (NONE is also a choice for default)
jessica.miller
Make sure you are both using the same .pkt file.  Different properties will show up with the same piece if the pkt you are using is different than the one your coworker is using.
Jessica Miller
Design Technician
CEC Corporation
4555 West Memorial Road, Oklahoma City, OK 73142
T: 405.753.4200
Dir: 405.753.4616
www.connectcec.com
in reply to: jroot
@jroot initially it was "none" and since I wanted to overcome the probelm i tried giving it a value of "right", even then it didn't work.
in reply to: jessica.miller
@jessica.miller Yes, I had created the file and my friend is using the same .pkt file
And Today it's working good, It seems restarting the application solves the problem.
Rail Community
