Subassembly and Multi Surface
neam
Message 1 of 25
neam
How to define a sub-assembly such as an attachment to produce a corridor in two different surfaces?
Thank you for your guidance.
Replies (24)
Message 2 of 25
CivilFlow
Try this out of the box subassembly:
Autodesk Civil 3D Help: DaylightMultipleSurface
https://help.autodesk.com/view/CIV3D/2020/ENU/index.html?guid=GUID-153AE7DD-0A8F-49ED-804B-AF9C82DA0...
If you need something more custom, you can use Subassembly Composer to tailor it to your needs.  This helpful video will help you get started.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 3 of 25
neam
Hi Mike:
Thanks for your explanation.
I'm familiar with what you said about the subassembly.
But in this type of subassembly can only be done bench in a place where the surface changes.
And unfortunately I am not very professional in subassembly composer.
Message 4 of 25
M_Obradovic
Hi neam
I create one simple Subassemby in SAC according your shetch. Please see attached PKT file (just rename ZIP to PKT when download) and check if will solve problem.
Regards
Message 5 of 25
neam
Hi Milos
Two points:
1. Left and right side not clear ??
2. The target surfaces is not clear ??
Message 6 of 25
M_Obradovic
What version of Civil you use?
Can you open pkt file in SAC and save as with different name. Than try import again in C3D.
Message 7 of 25
neam
Civil 3D 2019
Message 8 of 25
neam
I open pkt file in SAC and save as with different name. and import in C3D 2019 but no change any thing
Message 9 of 25
neam
in SAC every things is ok.
Message 10 of 25
M_Obradovic
Hi
Here is the same pkt file just renamed in SAC 2019.
I hope now should work.
Message 11 of 25
neam
Thanks you very very much milos.
Fortunately, it works well.
Only can the number of benches on the sides be variable?
Now puts two benches on the right and left side.
Because the depth of excavation varies in different sections.
Message 12 of 25
M_Obradovic
I add 3 bench more. If you need more benches tell me but I hope it is enought.
Message 13 of 25
M_Obradovic
here is PKT
Message 14 of 25
neam
I agree with you
It seems to be enough
Thank you again
Message 15 of 25
neam
Hi Milos
Is it possible to draw a feature line between sections during the production of the corridor?
Message 16 of 25
M_Obradovic
Hi
Yes it is posible, you just need to create point code for point which you want to create feature line.
Message 17 of 25
neam
In civil 3d corridor property or SAC???
Message 18 of 25
M_Obradovic
In SAC. If you have same skethc with name of feature line post and I will create codes in SAC.
Message 19 of 25
neam
Hi milos and thanks for attention
The same previous project,
Including bench in bench out and daylight
Message 20 of 25
M_Obradovic
I hope that is ok but please check codes.  And don't forget to import codes in CodeSetStyle in order to can create feature line in C3D.
