Import curved/straight pipe network from ArcGIS online or GIS datas
JC-OUAKNINE1
JC-OUAKNINE1
Hi every one,
After several tries, without success,
I expose to you my problem:
I published GIS datas on my ArcGIS portal.
As you can see on the picture, this simple network is composed of two structres connected to an original polyline section for the pipe.
I try to import them as rectangular concrete pipes, with specific dimensions (catalog and parts are ready in the drawing).
By importing them directly with Civil3D function "_AeccImportGISData", many pipes and structures are imported as a result of discretisation....
Whne I import them form Autodesk Conncector for ArcGIS, I obtain 1 pipe and 2 srucutres, but geometry isn't correct
See results on the iomage below attached.
Does anyone have an idea to help me ?
Jean-Christophe OUAKNINE
braudpat
Hello @JC-OUAKNINE1
With which ACAD CIVIL ?
-- CIVIL 2020 with Update 2020.5.1
-- Or CIVIL 2021 with Update 2021.2
THE HEALTH, Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
JC-OUAKNINE1
Hello @braudpat
Because I will need to work in parallel with OD & ODEDIT plugin(A.SHAROV).
JC-OUAKNINE1
Hi every one,
to precise that importation from ArcGIS online of the same data into InfraWorks is correct:
vincent.bonnefoiS9BT5
JC-OUAKNINE1
Thank you so much @vincent.bonnefoiS9BT5
It works fine, even in version 2020 !
Only rest the number of arc tessalations, I would prefer 2 sections: one line, then one curve.
Great solution !
