Civil 3D Forum
Stage storage elevation table - contour elevation shown are constant multiples of actual elevation.
7 REPLIES 7
Message 1 of 8
297 Views, 7 Replies
I have been working in a detention basin design project for which i need the stage storage table. My contour lies between 46 and 68 ft. However, when I use the stage storage function, the contour elevations it gives are multiple of 15 the actual one. For example: 46 is shown as 690, 47 as 715 and so on. and the incremental depth is 15 ft instead of 1ft. I have checked the contours and surface properties, all are showing the contour interval as 1ft and lying between 46 and 68 ft. What causes this and how can I solve this?
7 REPLIES 7
Message 2 of 8
pperales2
Are you using grading tools or feature lines to create the detention pond?
Message 3 of 8
LucasHicks
I got it to work, Civil3d 2022.1.1, what version are you on.
OpenRoads Designer, Civil 3D
Message 4 of 8
ChicagoLooper
Arcola, correct?
Is your basin named pond p? Did you make a copy and plop it down on Watts Plantation west of Knight?
You can manually enter the contour elevations. For example, from 46 to 68.
Chicagolooper
Message 5 of 8
in reply to: pperales2
yes i used feature lines to define breaklines for the pond
Message 6 of 8
in reply to: LucasHicks
I am on 2019..it works for mine too on pond r.. but for surfaces final pg and pond p it does not work
Message 7 of 8
Thanks for the solution...I'll use this
But for other surfaces, I don't need to enter this data manually. Do you have any idea on what causes this?
Message 8 of 8
in reply to: ChicagoLooper
Rail Community
