I have been working in a detention basin design project for which i need the stage storage table. My contour lies between 46 and 68 ft. However, when I use the stage storage function, the contour elevations it gives are multiple of 15 the actual one. For example: 46 is shown as 690, 47 as 715 and so on. and the incremental depth is 15 ft instead of 1ft. I have checked the contours and surface properties, all are showing the contour interval as 1ft and lying between 46 and 68 ft. What causes this and how can I solve this?
I got it to work, Civil3d 2022.1.1, what version are you on.
Arcola, correct?
Is your basin named pond p? Did you make a copy and plop it down on Watts Plantation west of Knight?
You can manually enter the contour elevations. For example, from 46 to 68.
Chicagolooper
I am on 2019..it works for mine too on pond r.. but for surfaces final pg and pond p it does not work
Thanks for the solution...I'll use this
But for other surfaces, I don't need to enter this data manually. Do you have any idea on what causes this?
