Civil 3D Forum
polylines to shape files
9 REPLIES 9
Message 1 of 10
9486 Views, 9 Replies
Need to create a shape file from an lwpolyline???
9 REPLIES 9
Message 2 of 10
jmayo-EE
Mapexport should do the trick.
John Mayo
Message 3 of 10
in reply to: jmayo-EE
thanks will give it a try
Message 4 of 10
derel
use the mapexport command. Select ESRI shp as the type and provide a path/name.
In the Selection dialog select Line as the Object Type and you and filter which polylines you want a few different ways.  On te Data tab you can choose any properties you want exported to Attributes and on the Options tab you can alter the coordinate system.
Message 5 of 10
antoniovinci
in reply to: derel
I love when Civil guys dare to answer to Map/Gis questions...
Ok, let's go to the point: I would argue about that, mr.Derel.
You choose "Line" if the polylines are open, but if they are closed (e.g. buildings' footprint) you have to choose "Polygon" with checked "Treat closed polylines as polygons" in Options Tab.
You'd ask: "What for, man?"
Well, if you load a polygonal shape in a Gis tool, it's easier to get info about an object by clicking "inside" it, without laboriously "aiming" on its linear boundary, isn't it?
Moreover, with "Polygon" you may export the topology of complex objects, e.g. islands or donuts.
Finally, no matter of type, in the Tab option you have the mysterious "Driver options" button, which allows you to export full 3D shapes like elevated contours.
Message 6 of 10
derel
in reply to: antoniovinci
Good to see that there are jacka**es in GIS.
Message 7 of 10
Murph_Map
in reply to: derel
You need to forgive antoniovinci, he's struck in 2006 versions and bosses won't let him upgrade.
Murph
Supporting the troops daily.
Message 8 of 10
antoniovinci
in reply to: Murph_Map
That's it, but let me tell ya something, my dear.
Since when I frequent this valuable forum, greedily I read your and other gurus' posts about FDO and similar news supported by newer releases than mine.
Even if I cannot practice them in my Map2006, theoretically I know many things about that, so I dare to answer "higher" questions, apologizing if sometimes I write follies...
Message 9 of 10
very helpful. Thank you!
Message 10 of 10
Pointdump
"I love when Civil guys dare to answer to Map/Gis questions..."
"Even if I cannot practice them in my Map2006, theoretically I know many things about that, so I dare to answer "higher" questions, apologizing if sometimes I write follies..."
Antonio,
I'd like to party with you, cowboy!
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Rail Community
