Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Model/paper space differences despite the same annotation scale
Message 1 of 18
I have to prepare a longitudinal section drawings for ditches. I put together a file with longsections and file which include labels for those sections. All is in scale 1:250, so annotation scale been applied to model and paper space. In the model space everything is fine, but in the paper space viewport, file with the labels is around 5mm off the original position. In the model tab is still ok. I could not find the answer anywhere, so I had to exploded and drop everything in one file.
If anybody came across this problem earlier or know the answer how to resolve it, please let me know.
Replies (17)
Message 2 of 18
Pointdump
Hi Rafal,
Welcome to the Autodesk Forums.
"...around 5mm off the original position."
A screen shot of the problem would help. Or maybe post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 18
Hi Dave,
I think I have added two images to the post once I published, but if this is not visible see below:
Model space
[cid:[email protected]]
Paper space for the same annotation scale looks like below (arrows are not pointing to the lines but slightly below)
Regards
Rafal
Message 4 of 18
Pointdump
Rafal,
No pictures are coming through.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 18
Dave,
Are screenshots visible?
Rafal
Message 6 of 18
Pointdump
Rafal,
Here's what I'm seeing. (Just text)
Are you posting with your phone?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 18
Dave,
Sorry for that. That was a printscreens. I am working through computer. Any other way to drop a picture here?
Can I send you a printscreens directly your email?
Rafal
Message 8 of 18
Pointdump
Rafal,
Are you clicking here?
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 18
pendean
Community Legend
Community Legend
DWG sample file with the problem please.
Also, to post pictures or share files you actually have to come to the website and reply: doing anything like that in your email software is not going to post here (anti-spam measures).
Message 10 of 18
Reply came from my email, so maybe that was a problem. Hope it is fine now. Model spaceModel spacePaper spacePaper space
Message 11 of 18
Pointdump
Rafal,
Screenshots OK now. And thanks for posting your drawings. Trying to repair broken references, and I don't have "dref-ditch corridors.dwg". So I'm missing the Profile View:
Dave Stoll
Las Vegas, Nevada
Message 12 of 18
Missing file should be in the folder of the uploaded zip file. Once you unpack zip file there should be folder B4 Sketches and the file is there - just linking missing file to that folder.  Hope that help.
I have noticed also if you have both referenced and you insert/bind them into main file they will "switch" in the model space like you can see on the image related to paper space.
Message 13 of 18
Pointdump
Rafal,
I have 3 drawings:
B4 Sketches folder >> Railhead-MCJ4-New basin.dwg
Railhead NEW-2021 May folder >> ACAD-Railhead-MCJ4-New basin-Text-Model.dwg
Problematic Annotation scale.dwg
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 18
Pointdump
Rafal,
OK, I was not matching up things correctly in the Xref Window. I'm now seeing what you're seeing.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 18
Dave,
Main file is Problematic Annotation scale.dwg
and two external references (xrefs) linked to the main file.
You can find those xrefs in the folders.
1. Railhead-MCJ4-New basin.dwg
2. ACAD-Railhead-MCJ4-New basin-Text-Model.dwg
File Problematic Annotation scale.dwg was eTransmited, so references are automatically put in the folder and zipped.
Once you unzip the file, you can see main file and xrefs packed in the folders.
I have checked that on my computer and worked.
Message 16 of 18
Pointdump
Rafal,
At first I was thinking >>>This<<< was the problem. But now I doubt this is a Linetype Scale Issue. I'm baffled. I sure don't see anything obvious.
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 18
Pointdump
Rafal,
I think this is the problem. Try changing this from 5 to 4:
Dave Stoll
Las Vegas, Nevada
Message 18 of 18
Joe-Bouza
Sounds like you are trying to cut and paste to the post
You have to save print screen local then use the forum interface to upload.
Also, what is the printed height of the annotation set to in the style composer / PS height for annotative text
Joe Bouza
