Importing Google Earth Image into Civil 3D Plan profile
Message 1 of 16
I would like to import a google earth background image for my plan production. I am using Civil 3D 2014. there is a method of importing KML through the toolbox but my miscellaneous utilities in the toolbox/Tool space lacks the option for Importing a KML. Any ideas how i can import a google earth image, will be helpful.
Thank you
Replies (15)
Message 2 of 16
tcorey
In Google Earth, File, Save, Save Image.
In AutoCAD, Attach.
There will be no world file, so you will need to rubbersheet the image manually or use AutoCAD Raster Design rubbersheet or imatch function, if you have that software. It's part of Infrastructure Design Suite Premium or Ultimate and AEC Industry Collection.
If you were thinking Google Earth image and surface, like you might have seen in the past, that was only available in Civil 3D 2012.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 16
Jeew-m
Dear Friend,
We can directly import google image from google earth to Civil 3d in the version 2012 as mentioned above. But for that you need to set the coordinates of your region in to civil 3D.
Or you can attach the google image to your drawing and move it to the correct location in your plan and re-scale and rotate it using reference points in your plan.
Also I think you can use Auto Desk infraworks 360 to do this as well.
Thanks.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 4 of 16
Thank you.
Message 5 of 16
Thank you. Ill try out Infra works and CAD earth
Message 6 of 16
sureshchotrani
You may be interested in below screencast, in Civil 3D 2016 onwards you can insert the map in file directly.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 7 of 16
sureshchotrani
Also can modify the same as show in below screencast
Message 8 of 16
I have been inserting images into c3d 2012 for years UNTIL TODAY. Does any know if google earth has completely severed connection with auto desk?
I get
Message 9 of 16
saifumk8
Message 10 of 16
eng.ksoliman
I hope this video help you.
Message 11 of 16
Love this workflow, however within QGIS where is the Openlayers plugin ???
Message 12 of 16
Ntuthuko.
Hi
Where is this map coming from? Is this Google Earth?
Ntuthuko
Message 13 of 16
ishaq03
Hi Everyone,
After using the map export command  then bring into QGIS The image is not coming properly it's asking to set ApI key
any advise please.
Message 14 of 16
TerryDotson
It's likely coming in properly, but the results are watermarked to prevent usability.  You can sign up with Google and provide credit card information ($$$) to obtain an API Key.
However, if you do some research, you will likely find similar or perhaps better quality images provided at no charge by the government agency covering your area of interest.
Message 15 of 16
fcernst
Dotsoft has a great tool in their offering that accesses various high resolution image Tile servers to quickly download into Civil 3D.
I use these to create exhibits in Civil 3D….
…Export them using Autodesk Raster to quickly create geolocated images with World files, and import into various H&H modeling software as Background images.. well worth the entry price
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Message 16 of 16
TerryDotson
…Export them using Autodesk Raster to create geolocated images with World files,
Thanks for the mention, the add-on also has an Image > World Make tool to create world files from a selection set of images properly positioned (by any method) inside a drawing, should eliminate the need for ARD in this one case.
