Civil 3D Forum
How to control View - Roll Angle?
1 REPLY 1
1065 Views, 1 Reply
I found out that the XREF files came in to drawings automatically rotated by 90-deg; but all the Coordinates are at the correct place.  After investigating, I suspect it is the default drawing set-up for the VIEW -Camera - Roll Angle = 90-deg.
A few questions here:
1. How to control View-Camera - Roll Angle?
2. Why roll-angle is set-up to 90-deg by default? (please note that no camera was set-up in the drawing).
3. Why the XREF files are all rotated but the coordinates are all good?  That is a mystery to me.
Please also note that all drawings are in UCS-World.  So, the rotated XREF files are not related to UCS Z-rotation.
Labels (3)
1 REPLY 1
Wojtek_Garczewski
Hi @Anonymous
Seems your Plan View is not set up to World and it is rotated by 90degrees.
Can you try the command PLAN -> World, then check if Roll Angle is set to 0 and how it behaves with xrefs, please?
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Technical Support Specialist
Civil Engineering Solutions
Rail Community
