I found out that the XREF files came in to drawings automatically rotated by 90-deg; but all the Coordinates are at the correct place. After investigating, I suspect it is the default drawing set-up for the VIEW -Camera - Roll Angle = 90-deg.
A few questions here:
1. How to control View-Camera - Roll Angle?
2. Why roll-angle is set-up to 90-deg by default? (please note that no camera was set-up in the drawing).
3. Why the XREF files are all rotated but the coordinates are all good? That is a mystery to me.
Please also note that all drawings are in UCS-World. So, the rotated XREF files are not related to UCS Z-rotation.
Hi @Anonymous
Seems your Plan View is not set up to World and it is rotated by 90degrees.
Can you try the command PLAN -> World, then check if Roll Angle is set to 0 and how it behaves with xrefs, please?
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
