Civil 3D Forum
Help With Assembly Baseline Error
1 REPLY 1
gpserra
347 Views, 1 Reply
I was reviewing a corridor I've been putting together for the past couple of days and realized I forgot to switch some of the assembly from a 6" curb to a 4" mountable curb. I went to swap the assembly in the corridor property and it gave me the error on screen. I figured the baselines for the intersection curb return was not allowing me to update the assembly, so I deleted the baselines and with them the regions for the curb return. Rebuilt the corridor, try to change the assembly and still the same error appears.
Any help is appreciated.
Thank you.
Tags (2)
1 REPLY 1
user181
in reply to: gpserra
The error says the start and end station for those regions is both 0+00.  In the corridor parameters change the end station for those regions from 0+00 to the end station value.  If you need to you can post a dwg file for someone to look at.
Rail Community
