07:37 AM
- Mute
- Permalink
- Report
I am having an issue with the surface as created from the corridor. I have an alignment, design profile drawn at the proper elevation and I have an assembly but for some reason the surface is not being created properly. I have deleted corridor and redrawn everything only to run into the same issue when I select the surface it says the max/min elevations "{value too large to format}". I am out of ideas of how to modify or adjust this to get it to display properly.
