Pressure Network Part Tables Offset Side
MSchille-1994
MSchille-1994
To All,
I am trying to utilize pressure networks for a project here in town where we are putting in new water main.  By City standards I need to table the fittings and appurtenances, much like you can with gravity network structures.  However, when listing the station and offset in the table of fittings, there is no option to list the offset side.  I can do this with a single label in plan view by adding reference text to the label style, but you cannot add reference text to a fitting or appurtenance table.
Anyone else run in to this issue?  I am on version 2020.4.  We have a 2021 version in our office and this option is not available in that version either.  I have tried expressions, but they won't return non-integer values.  Also, I have tried manually editing table text like you can an individual plan label, but that option doesn't even exist.
Ideas?
Attitude, not Aptitude, Determines Altitude
tcorey
You can put brackets around values to the left of alignment. These are considered negative numbers, so format the Insertion Point Offset, Sign value. Having 24.5 vs. (24.5) makes it easy to tell what is left, even though it doesn't say the word.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
