CORRIDOR SURFACE NOT SHOWING UP
I am having an issue with the surface as created from the corridor. I have an alignment, design profile drawn at the proper elevation and I have an assembly but for some reason the surface is not being created properly. I have deleted corridor and redrawn everything only to run into the same issue when I select the surface it says the max/min elevations "{value too large to format}". I am out of ideas of how to modify or adjust this to get it to display properly.
Jeew-m
Have you added data to the surface (like top codes)
The bottom data of properties (too large etc) are not a problem. It shows up in my drawings also.
Make sure your surface style is set to show data. Sometimes it may be set to No Display
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
How do you add codes? I see where it is in the properties and how to modify but im not sure what to modify it to? My company has a template in the drawing but which of the ones below would I need to change?
OK so yes you are correct @Jeew-m . I have to add it in the following menu in order for it to show up.
once this is done I hit
"ok" and it showed up.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
