07:05 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Attached is a DWG file with a couple images showing areas in my surface model that I need to correct the surface triangulation. It appears that there is not very good triangulation in these areas, and it is causing incorrect contours. I understand the concepts of swap edge and add line, but I cannot find a combination of these commands that will fix the triangulation in these areas. Any tips or tricks that I could use to fix the triangulation in this area will be very helpful.
The surface was created using grading objects.
Thanks in advance.
