Has anyone else experienced severe lag and even exception errors when editing or changing survey figures add to a drawing from a C3D 2020 Survay Database?
We and a host of other firms are having issues with using survey figures from a 2020 Survey database, whether created new in 2020 or a converted database from 2018. The closest I can come to anything on the knowledge base is this: https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal...
Is creating Survey database on local devices the real solution, or just a work around for now?
This doesn't seem to address the lag, lock and slownesss experienced when editing survey figures that do not cause it to crash. This issue does not seem to happen on every Survey Database project using the same device with the same setup as long as the hardware accelerator is turned off.
I can supply datasets upon request. Just want to know if anyone has experience or insights on this issue.
Thanks.
