Civil 3D Forum
Convert Profile to Polyline
12 REPLIES 12
Message 1 of 13
14599 Views, 12 Replies
Is there a way to extract a simple polyline from a profile in Civil 3d 2010?  I simply want to offset the proposed profile to indicate another feature, but can't seem to find a way to create an offset-able polyline out of the proposed profile.
12 REPLIES 12
Message 2 of 13
AllenJessup
Offset horizontally or vertically? What version are you using?
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 13
in reply to: AllenJessup
I want to offset the profile vertically within the profile view.  I'm using Civil 3d 2010.
Message 4 of 13
neilyj666
Change it to static, offset as you wish then change the original back to dynamic. (The offset isn't dynamic but creating and sampling another surface would get a dynamic profile)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 13
Sinc
Why try to turn a Profile into a polyline?  A polyline can't represent the curves in a Profile, so if you have any vertical curves, the polyline would have to be tesselated.
Why not just copy the Profile?  (Select the Profile, right-click -> Edit Geometry, then use "Copy Profile" in the Profile Geometry tools.)  Then raise/lower the copy by the desired amount.  This also gives you the benefit of being able to put Labels on your offset Profile.
Sinc
Message 6 of 13
AllenJessup
in reply to: Sinc
Not that I don't agree that you should stick with Civil 3D objects as much as possible and I don't know the OPs intentions. But your suggestion runs into the same problem as you would with a Surface. Raising or lowering is not an offset.
Since most design is based on a height above ground of some other reference. Raising or lowering a copy would be appropriate. But in a case where an actual offset is required (can't think of an example myself) then is doesn't work.
Allen
Allen Jessup
Message 7 of 13
neilyj666
I presumed the OP wanted to "offest" by raising or lowering which won't obviously be a true offset but sometimes is adequate for the purpose- perhaps he/she will clarify the intent
Message 8 of 13
AllenJessup
in reply to: neilyj666
I agree. As I said I couldn't think of any reason why you would need a true offset. But the OP may have more imagination than I do of his bosses may be crazier than those I've worked for!
Allen
Allen Jessup
Message 9 of 13
jim.poole
Quick dirty method for creating polylines from profiles.
1) Save the drawing as a new version.
2) Delete the surface that the profile is generated from - the profile becomes an editable entity.
3) explode it into a block, then into lines.
4) JOIN the lines - bingo
Message 10 of 13
in reply to: jim.poole
jim.poole, yours is the only true answer. Thank you Jim, this worked perfectly.
Several examples of things not answering the OP's question:
Why not just copy the Profile? Then raise/lower the copy by the desired amount.
I presumed the OP wanted to "offest" by raising or lowering...
Message 11 of 13
cwr-pae
One more option that may give desired results. Create a feature line from the alignment, project it to the profile view, then raise/lower as is or explode, rejoin and offset.
Message 12 of 13
cwr-pae
An easier quicker way. Explode the profile, copy to clip board with base point 0,0 and undo twice to get the profile back. Then paste to 0,0.
Message 13 of 13
KirkWM
I believe there are a few apps in the app store that can speed this up as well. There's a free one called "
Reference Polyline From Profile" seems like what you are after, and Red Light has one for $10.
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=3240925303390256952&appLang=en&os=Win64
Rail Community
