I went to do volume calculations today and the panorama window will not show up.
I have tried shrinking my window and viewport to try and find it. I have also tried toggling it in toolspace menu. When I run the _AeccVolumesDashboard command it does not give any errors or cancel out.
Some help to get my panorama back would be much appreciated!
Hi andrewsS3MSY!
Take a look at the information below, and let me know if it helps:
Hello @andrewsS3MSY, I just wanted to know if my recommendation helped you (please click on "Accept as Solution" if post helped you resolve the issue) or if you found a different solution (please share it with the Forum users). Otherwise, let us know if you need more help.
Thank you for your answer.
Did uninstalling an reinstalling solved the issue?
If so, please click on "Accept as Solution".
Rick Jackson
Survey CAD Technician VI
I had the same problem today. In case someone else runs into this again, I typed "DOCKPANORAMA" into the command line and it showed up above my tool space. Then I could move it to where I wanted it.
I saw another article suggesting that I minimize the drawing while leaving Civil 3d open, but I still couldn't find it.
I'm having the same issue. Panorama window is non-existent in my install. I need it, have a project due, and of course I can't reinstall my software. This is really sad. I'll have to find a work around but autodesk needs to address this and not with some tech who is looking for points in the forum.
First Execute
Command: ShowEventViewer
then
Command: DOCKPANORAMA
Then the panorama palette should be docked and visible in most cases.
If still not visible, activate the panorama palette editing your current civil workspace.
Command: _CUI
