Civil 3D 2017 - Alignment stationing lengths do not match length of polyline.
Message 1 of 22
I am trying to create an alignment from a series of polylines. I scaled a PDF to actual size in model space but when i create an alignment from the centerline, the stations are spaced along the line at 4' intervals rather than 100'.
I have tried changing my drawing units from inches to feet but this does not change the scale of my alignment.
Replies (21)
Message 2 of 22
rl_jackson
Try -DWGUNITS and verify that the drawing is in FEET (2)
Rick Jackson
Survey CAD Technician VI
Message 3 of 22
My drawing units are currently set to feet
Message 4 of 22
ilia.borisov
Try right click on labels>edit alignment labels and look for increment value
Message 5 of 22
My increments are set to 100' modifying this does not seem to fix my issuejpg3.jpg
Message 6 of 22
ilia.borisov
Maybe im wrong but i understand that you want labels space 100
Message 7 of 22
yes i would like to show the correct stationing at 100' intervals along my polyline. however the alignment scale seems to be different than the scale of the lines in my drawing.
thank you everyone for the replies!
Message 8 of 22
ilia.borisov
Try to change units settings from here
Message 9 of 22
I seem to have the same issue when I change everything to feet and vice versa to inches.
Message 10 of 22
here is a step by step of what happens when I make an alignment out of a 100' polyline.jpg4.jpgjpg5.jpgjpg6.jpgjpg 7.jpg
the length of the alignment comes out as 1200' (obviously some sort of inches vs feet issue) I just cant seem to pinpoint why the alignment scale does not match the scale of the line.
Message 11 of 22
ilia.borisov
Message 12 of 22
unfortunately im finding that changing all of these units is only changing the units the station is diplaying and not solving the problem that my alignment length is always 12x the length of the line/polyline used to create it...
I've been messing with all the permutations of units between feature line and drawing settings.
ive tried dimension units, distance units, coordinate units, and different combinations between feature settings and drawing settings. They alter how the lengths are displayed by units but my alignments are always 12 times as long as the geometry i used to create them.
Message 13 of 22
ilia.borisov
Distance is what you have to change
Message 14 of 22
I have tried all combinations of distance units between feature drawing settings and drawing settings
feet-feet
feet-inch
inch-feet
inch-inch
i still have the same issue where the alignment is 12x as long
Message 15 of 22
ilia.borisov
Can you attach the drawing
Message 16 of 22
rl_jackson
Civil3D only works in Feet or Meters and that's it..... You should start a drawing with a Default Imperial or Metric Template and all settings will be set as they should be. If you don't want all the NCS layers then start the drawing with No Template based on your units.
Rick Jackson
Message 17 of 22
attached
Message 18 of 22
LucasHicks
Your units are set to Architectural in the lower right of the screen.  Change to decimal and you'll see that your line is 1200' long in the properties.
OpenRoads Designer, Civil 3D
Message 19 of 22
I see, will alignments always operate off of decimal feet?
Message 20 of 22
rl_jackson
C3D only works in feet or meters and both are reported in decimals only. How the units in your file got messed in the first place is bewildering. Simply starting with the a default feet or meters template will not cause the issue you described so you must have opened a AutoCAD file that was created by architect and didn't import styles and settings to override all the places that units get set
Rick Jackson
