Hi watch this video starting at 1:12 minutes - I was pulling out my hair.
https://cadpilot.com/home/jump-on-c3d/jump-on-c3d/2022/10/25/enter-the-civil-3d-2023.2-update/
Use AECCLABELOPTFLAGS = 1
Adaptive Labels with Level of Detail Support
This new and optional performance feature called Adaptive Labels supports Civil 3D Group Labels in Profile Views and Section Views. The new code is designed to reduce the redraw issues of lots of Civil 3D Profile View and Section Views Groups labels in larger Plan Production Plan and Profile and Pages of Sections Sheet drawings.
There are new commands in the Ribbons and the Status bar to implement Adaptive Label redraw control.
In the updated Civil 3D Status bar, the Adaptive Label Group icon manages the new AECCLABELOPTIMZE system variable. When this is turned on Group Labels that are outside the modelspace viewport range are not drawn.
We might consider this a WYSIWYG approach where Civil 3D ignores and does not redraw the unseen.
The following non-staggered labels are supported for Adaptive Label Groups:
- All Alignment label groups.
- All Profile label groups.
- All Section label groups (section offset label group, segment label group, grade break label group, etc.)
- All Profile View band label groups.
- All Section View band label groups.
A new AECCLABELOPTFLAGS system variable managed by the Adaptive Label Group interface tool allows us to control and manage the redraw behavior of Group Labels in Profile Views and Section Views.
- 0 Neither of above two settings are turned on
- 1 Regen the labels if needed when the view is panned or zoomed
- 2 Reduce the number of labels that are drawn inside the viewport
- 3 Both the above two settings are turned on
We can easily test the Adaptive Labels and see how these new interface controls and system variables work with a single Profile View and an added group of Profile View Band Styles.
