Civil 3D Forum
C3D 2021 - Viewport lock does not appear in the Right Click Menu anymore
45 REPLIES 45
Message 1 of 46
3602 Views, 45 Replies
Any idea why the viewport lock does not show up in my right click menu anymore? It was there, and then one day it was not. I am not sure why.
We have upgraded 3 seats to C3D 2021 and all 3 have the same issue. The 2020 seats still have the viewport controls in the right click menu. I have been using 2021 for a month now and i think it was fine. I just noticed this happened. The other 2 seats were upgraded to 2021 within the last 2 weeks. Both were for new hires that would not have noticed anything different.
Pickfirst is set to 1.
I am only clicking on the single viewport. No multiply selections.
Options - User Preferences - "Shortcut menus in drawing area" is checked.
45 REPLIES 45
Message 21 of 46
jae.kwon
Following worked for me:
1. open cui
2. unload the partial acad.cuix
3. load the partial acad.cuix (from %appdata%\Autodesk\C3D 2021\enu\support)
4. apply & ok to save changes to the cui
Give that a try.
Message 22 of 46
DentonYoder
in reply to: Jeff_M
Is there a way to just menuload the partial cui file that has the mview edit functions?
Message 23 of 46
DentonYoder
I think I did the above directions correctly, but got no benefit.
I did the command cui and under partial I unloaded acad; then hit the open icon and browsed to appdata roaming autodesk... c3d enu support and selected the acad.cuix... no change.  Do I need to force something to re-compile or edit the file first?
Message 24 of 46
jae.kwon
in reply to: DentonYoder
Shutting down C3D and restarting it maybe?
That's odd... the unload/reload acad.cuix fixed it for half a dozen people I've talked to about it so far. I'll post an update if I find anything new.
Message 25 of 46
codee
in reply to: wfberry
Keeping the properties menu open at all times GREATLY reduces the selection speed of 3D objects and labels.
Message 26 of 46
DentonYoder
It also reduces screen space.  I miss my old hitachi 1212e digitizer!  It let you get ALL the icons off the screen and have them on a board where they never moved!  Mice suc
Message 27 of 46
hencoop
in reply to: Jeff_M
@Jeff_M I'm a little late to this party but your help has been invaluable as usual.  With your help I was able to copy the Shortcut Menus "Viewport Object Menu" and "Viewport Objects Menu" from Partial Customization Files>ACAD>Shortcut Menus to CIVIL>Shortcut Menus and get the View Clip... options restored.
Even so, I was still getting frustrated trying find how to delete my existing viewport clipping.
I was thinking there must be a new command for deleting viewport clipping since the VPCLIP prompt is: Select clipping object or [Polygonal] <Polygonal>:
Finally, on a hunch I entered "D" at this prompt.  Sure enough!  The "Delete" option exists behind this prompt!
There are far too many AutoCAD commands that DO NOT include all of the valid options!
I wish Autodesk would pay closer attention to these details as much as they do to adding new features
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Ver.: 13.6.1781.0 Civil 3D 2024.3 Update
Built On:        U.152.0.0 AutoCAD 2024.1.2
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Message 28 of 46
Kevin.Dittman
in reply to: Jeff_M
good solution
Message 29 of 46
scmallory
I completely agree, the loss of this function wastes time. I typically use the Auto-Hide feature with my Property dialogue box. There is always a slight delay opening the dialogue boxes on autohide. As well, I can not clip the viewport through the property dialogue box.
Select the viewport and type VPCLIP, I feel will be the fastest solution, if the right click function is eliminated.
Message 30 of 46
AllenJessup
in reply to: scmallory
I edited the CUI as suggested by @Jeff_M and shown by @hencoop .  I didn't even remember it was missing until your post.
Allen Jessup
CAD Manager - Designer
Message 31 of 46
hencoop
The big problem with this change is that a viewport that has already been clipped cannot be selected... even with selection cycling turned on.
... So, I was confirming this and it is absolutely true that you will NOT be able to select the viewport (when selection cycling is turned on).
However, if you select the clipping polyline instead you will have actually selected the viewport (or else the prompt is in error and it should be "select viewport to clip OR select viewport clipping boundary").  Nevertheless, if you struggled with selecting clipped viewports like I did when selection cycling is turned on, turning selection cycling off and/or selecting the clipping polyline will allow you to delete the clipping boundary or create a new clipping boundary.
Message 32 of 46
AllenJessup
in reply to: hencoop
I don't seem to have any trouble selecting a clipped viewport with selection cycling on. I clipped a rectangular viewport with an irregular polyline and could still select itl
I also was able to select it with cycling off.
Allen Jessup
Message 33 of 46
hencoop
in reply to: AllenJessup
My system refuses to select the Viewport if I choose Viewport from the selection cycling menu.  It works if I choose the Polyline from the selection cycling menu.
Message 34 of 46
DentonYoder
My favorite clipping it to draw anything I want and turn it into a section
with the region command. Then use union, subtract or intersection to
refine what I want or put a hole in the mview... then use the mview command
with the object switch and select your 2d section. Poof, you have the most
interesting mview ever created!
denton@vt.edu
Message 35 of 46
hencoop
I'm not sure I follow you but it sounds interesting.  If you have time could you make a Screencast of how you do that and post it?
Message 36 of 46
AllenJessup
Yes. I use that method when I want to create a "keyhole" viewport. Most of ours are boring rectangles. But it's nice to get creative once in a while.
I also have used that method to get areas such as Impervious Surface. Then use fields to get that into a table.
Allen Jessup
Message 37 of 46
AllenJessup
Any variation on this should work.
Allen Jessup
Message 38 of 46
DentonYoder
My Paperspace video is: 07 Paperspace - YouTube
I cover mview from regions at exactly 16 minutes into the video.
Message 39 of 46
DentonYoder
It looks like it stripped the link out
https://www.youtube.com/watch?v=2S2rxBIFObE
16 minutes in I start region based mview
Message 40 of 46
hencoop
@DentonYoder I see.  I don't use region or union except when working with 3D solids and I rarely do that.  I do use polylines with arcs and circles to make some viewports.  Most often it is for blowup details on my as-built P&P sheets.  If there isn't a suitable clear space in my plan I'll keyhole the plan and put my blowup detail in the keyhole as another viewport.
One thing I can take away from this is that it seems much easier to use Union to make the clipping boundary than it is to trim circles and polylines and then Pedit Join them.  I like easier!
Rail Community
