Is there a way to find an AutoCAD - DWG Viewer & Editor or PC? I have some co-workers that would like to see some info about my drawings.
Solved by pendean. Go to Solution.
the DWG viewer is only for viewing
DarrenP
Ok...
With all due respect.
Is there a way to find one? Free or not... please... Cause, I have one on my Trimble TSC7 , and it's free.
See if anything here fits your needs. I don't think there is anything that will work with Civil objects. Set PROXYGRAPHICS to 1 before saving the drawing.
https://www.cadstudio.cz/en/download.asp
Allen Jessup
CAD Manager - Designer
Are they needing to make notes or actually work on the drawing? Because if it's just for making notes then use Design Review in conjunction with TrueView. You can then overlay the markup directly into AutoCAD.
As for finding a free program you're probably not going to be happy with what you find. Depending on what you're trying to accomplish why not use AutoCAD LT? It's not that expensive.
