Civil 3D Forum
ARCH CULVERT DESIGN
4 REPLIES 4
sanetdikkumbura1950
299 Views, 4 Replies
ARCH CULVERT DESIGN
What is the easiest way to draw an arch culvert of the following type? or there any other easy way to do this besides civil 3d?  I need to make the plans and quantities for an arch culvert project.
Thank you.
4 REPLIES 4
Hello, @sanetdikkumbura1950!
Here in Brazil we are used to model these structures in Revit. In our workflows, this is easier than using Part Builder or Inventor workflows to model it in Civil 3D. In Revit, it is possible to set tables of quantities and drawings in different perspectives (front view, 3D view....). This is an example for a Box Culvert:
Hope it helps!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
@Matheus-Lima Thank you for the reply. are you exporting the culvert drawn in Revit to a civil3d surface?
No problem, @sanetdikkumbura1950!
We get everything together in Navisworks to coordinate the designs, as it is able to import both DWG and RVT or IFCs. Therefore, the Revit model goes directy to Navisworks in our workflows. Another option is using Model Coordination tools from the Autodesk Construction Cloud like this: https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-38CC3A1C-92FF-4682-847F-9CFAFCC4CCCE.
Cheers,
Matheus Lima
Short of reaching out to the manufacturer? https://www.conteches.com/bridges-structures/
Matthew Anderson, PE
Rail Community
