Civil 3D Forum
LandXML surface size limit
5 REPLIES 5
dhenderhan
289 Views, 5 Replies
I have a huge surface (.mms is 467mb) that I attempt to export to .xml and after 10 minutes, it creates an empty .xml file. Is there a size limit on surface LandXML exports?
David E. Henderhan, PLS
Civil 3D 2025
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
Labels (1)
5 REPLIES 5
VincentSheehan
in reply to: dhenderhan
There must be. I run into the same issue all the time. I use Infraworks to import the XML then export from there into Civil 3D.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
VincentSheehan
I just realized you are exporting from Civil 3D, not importing.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
rl_jackson
With the .mms file I would recommend simplifying you drone based data (simplify surface) until the mms file no longer exists.
Rick Jackson
Survey CAD Technician VI
I guess that your surface is something like the natural ground or existing ground that created from several input such as DEM file, large Lidar file, etc, that why your civil 3D file  was created .mms file.  if this case I will not export the civil 3D object to the LandXML file. LandXML file is work if your civil 3D object are not tool big, it is fine for alignment, design surface such as Embankment dam surface etc, like this below that i export only design surfaces.
that mean you should think to do not try to export for the large civil 3D object especially the civil 3D surface that with mms file..
Try reducing the output to simply Points.
Matthew Anderson, PE
Rail Community
