Rename Coordination Spaces
Simple really: I would like the ability to rename Model Coordination "Coordination Spaces".
24 Comments
We also want the ability to rename the Model Coordination "Coordination Spaces" and also change the Folder Path of the Coordination Space to select an other folder in the project.
In addition to renaming these coordination spaces, we should be able to delete / rename these spaces as needed.  Early on in the project we have no clear picture of how each project will be broken down for coordinating, adding / subtracting to areas is pretty common.
hamid.behroozi
I believe it is a necessity to be able to edit the coordination spaces. even be able to delete, rename, change the path etc
Flies-Eyes
As everybody else is saying, pretty basic functionality.
Remove
Deactivate
Repath
Rename
The system doesn't even let me create a new Coordination Space at the moment.  Explain to me again why we are paying for services that don't work and are not available......  Don't worry I will just call my client and let them know the project is on hold while someone at autodesk sorts it out....
johan_van_mol
Such a disappointment.
Autodesk is really cutting corners in ACC.  A lot of basic functionality is missing.
A nice simple acronym exists in computer science: CRUD: Create-Read-Update-Delete.
Customers want to be able to CRUD everything.
We want to be able to:
* Create-Read-Update-Delete Coordination Spaces
* Create-Read-Update-Delete Roles
* Create-Read-Update-Delete the shared folder in "Design Collaboration"
(other BIM 360 ideas exist for these functionalities)
You can't expect your customers to be super-humans and do everything right the first time.
Everything in ACC should be update-able or delete-able.
SteveDFThorne
I didn't know about that acronym but I always wondered if there was some standardized rules for general software design absolutes.
Thanks for sharing this. Now if only Autodesk would adhere to it closer....
I believe it is a necessity to be able to edit, delete, and rename coordination spaces as an administrator.
m.tradDBEVE
Still nothing ? 😞
Come on Autodesk 😕
A.Nafea
bshaikhmohd
Observer
I need to rename and delete the coordination space @Anonymous where is the solution
sahil_nama6EUXZ
Observer
After 3 years and 100+ votes, this feature is still missing.
serhan.genc
Doesn't someone from Autodesk hear us for many years?
renato.pedrotti
Observer
Hello everybody.
My buddys and I strongly agree with this topic.
Enforcing johan_van_mol's request, we need to Create-Read-Update-Delete (CRUD), everything.
Citing Johan:
Everything in ACC should be update-able or delete-able.".
MichaelWolff
How much longer will it take to fix this bug?
Zhars
As mentioned by everyone above, need to be able to Edit, Delete!
montasser_ghonimAMYFH
Community Visitor
Also, we need to include the NWD format
Ben_vanbuskirk
Community Visitor
As mentioned by everyone above, need to be able to Edit, Delete! Please Fix this
Flies-Eyes
And people still question me as to why I don't consider this platform to be ready for market....
maciej-wypych
That's why we've built our own tool to do this. The API is available. If you're interested if your own app, let us know.
SteveDFThorne
That's interesting that there is an API to do this. I was expecting Autodesk to have had a good reason that this was not an option. Seems like they really should implement my suggestion then. Does anything break when you rename it with your app?
Technology Administrators
