Show only
Search instead for
We also want the ability to rename the Model Coordination "Coordination Spaces" and also change the Folder Path of the Coordination Space to select an other folder in the project.
In addition to renaming these coordination spaces, we should be able to delete / rename these spaces as needed. Early on in the project we have no clear picture of how each project will be broken down for coordinating, adding / subtracting to areas is pretty common.
As everybody else is saying, pretty basic functionality.
Remove
Deactivate
Repath
Rename
The system doesn't even let me create a new Coordination Space at the moment. Explain to me again why we are paying for services that don't work and are not available...... Don't worry I will just call my client and let them know the project is on hold while someone at autodesk sorts it out....
That's interesting that there is an API to do this. I was expecting Autodesk to have had a good reason that this was not an option. Seems like they really should implement my suggestion then. Does anything break when you rename it with your app?
