Measurement Tool in Glue
Hi, at this time we're having a project completely without traditional drawings. I represent a general contractor, and in this project the only design material we get from the designers is a combined model in .nwd format.
We are trying to use 360 Glue (and Field/Layout) to manage the building process. I'm going to post a few enhancement needs, this being the third one.
When using the measure tools in Glue it does not seem to reqognize lines, just points and surfaces. This can make it quite hard to measure sertain elements, eg. when in a section
It would be great it the measure tool in Glue would have at least the same possibilities as in Navisworks. Also, there should perhaps be a small drop down to lock the orientation of measurements, not only the keyboard shortcuts?
Anyone know of a good way to reset the "lock" function when doing measurements?
Best regards, Inge Handagard
1 Comment
Glue is underutilized because it doesn't have the measure & clash functionality (including options) as Navisworks. Autodesk, please add these tools into GLUE & ultimately B.I.M. 360 Coordination.
