HI,
Lightning tool developed using Bifrost 2.1 version point cloud. And, I used this tool to make the first demo. You need Bifrost 2.1 version and Rebel Pack 0.3.0 to run this tool.
This is only the first version, and I hope to update it in the future. My goal is to make it easy for everyone to create any type of lightning effect.
Of course, I also hope that the official BIfrost team can release better lightning tools in the future.
I upload the file here. And, I will upload it in the compound sharing area.
Please enjoy!
Thanks!
Demo:
Tutorial:
HI,
Please enjoy!
Thanks!
Demo:
Tutorial:
Has anyone had luck with getting levels 2 & 3 or particles working in Maya 2022.3?
Thanks to Macintosh for helping the community out with showing how to fix/update the tool.
This is the last thing that is holding me back. I can't get those secondary options to take.
Hi everyone, Sorry, this is the latest fix version and it works in 2.4 Thanks.
Thanks for the update!
I'm trying to figure out how to install/Import the downloaded file, can someone please help?
You need to make a folder to place the compounds in. The latest Rebel Pack needs to go here as well.
Windows: C:\Users\username\Autodesk\Bifrost\Compounds\etc...
Mac OS: /Users/username/Autodesk/Bifrost/Compounds/etc...
Read my reply again. You need to make the folders…
it won’t be there now because you don’t have any compounds yet.
Is there a newer compound Simulate Lightning? ... Maya 23, Bifrost 2.5 Straight out of box i get this error.
Macintosh postet a video on how to fix it here.
https://forums.autodesk.com/t5/bifrost-forum/bifrost-develops-lightning-tool-demo-1/m-p/11098364#M68...
Hi there,
Following your steps I ma able to make it to work however I was not able to get any result from L2 and L3. DId you get thoem to work? Any help will be great. Trying to show to my students too.
Hi there,
if you are in Discord grab it from here. I fixed the tool plus the resample. There are 2 compounds there. That will make work everything.
https://discord.com/channels/872260298508222534/1030205498852647013/1030210911820062850
I joined the Discord, posted an elaborate post on how I fixed this, and then an admin deleted it because I posted it wrong. Didn't even give me a change to save it first. All that work just gone. I left the Discord after that.
And i apologized and do it a second time. We are sorry that it happened its not our intention to delete posts. We make now sure this doesn't happen again.
I know and I appreciate it. Thank you. I promise not to bring it up again.
Hello, I'm very new to using Bifrost in Maya. What file directory did you put your simulated lighting in? Whenever I hit the tab key in the Bifrost Graph Editor I don't see the simulated lighting appearing on the list that appears. I would really appreciate it if someone could help me with that. Thank you
I appreciate the help. One issue that I came across was that I don't see a Bifrost folder after I clicked on the Autodesk folder. Do I need to create a Bifrost folder? Or is it possible that I put Bifrost the folder in the wrong spot
