Bifrost develops lightning tool demo 1
Bruce.Lee.
Message 1 of 143
Bruce.Lee.
HI,
Lightning tool developed using Bifrost 2.1 version point cloud. And, I used this tool to make the first demo. You need Bifrost 2.1 version and Rebel Pack 0.3.0 to run this tool.
This is only the first version, and I hope to update it in the future. My goal is to make it easy for everyone to create any type of lightning effect.
Of course, I also hope that the official BIfrost team can release better lightning tools in the future.
I upload the file here. And, I will upload it in the compound sharing area.
Please enjoy!
Thanks!
Demo:
Tutorial:
Replies (142)
Message 121 of 143
sepu6
Just created if not there just as mentioned above /Bifrost/Compounds
Message 122 of 143
runnyroot
Community Visitor
Community Visitor
hello I am getting this error while using the lightning pack and Maya Bifrost version in 2.4 I have tried all the methods but still giving this error can anyone help me as i am new to the bifrost
Message 123 of 143
takaharu_tobe
I'm using maya2023 bifrost2.7.1
In my case "resamplestrands" is giving an error.
can someone please help?
Message 124 of 143
sepu6
is because there is a nan (an error) on that compound. Here is a fixed version for BF 2.7.1, 2.8,  etc...
Message 125 of 143
takaharu_tobe
@sepu6 @Bruce.Lee.
Thanks!
error no longer occurs!
Message 126 of 143
mihirsbcc
Trying to open the lightning tutrial with Maya 2024, rebelpack 3 and 4, bifrost 2.6. The compound is all red. Is there a new version or it will only work with previous version of Bifrost?
Message 127 of 143
sepu6
The version I posted works with 2.7.1 and up. If you are using M 2024 then you can update to the latest without problems.
Message 128 of 143
mihirsbcc
Thanks a lot. I tried to remove some ports of the older compound, didn't work.
Message 129 of 143
faustin.compagne9PEV9
Observer
Observer
Hey i have un pb with imput3 and imput6 on my scatter point amount, help pls !
"scatter_points2", Error: while compiling top level compound 'bifrostBoard1', around the port 'bifrostBoard1::simulate_lightning::scatter_point2.amount' : no promotion exists from a value of type 'double' to a value type 'float'
Message 130 of 143
sepu6
Check the message above. I fixed a bug and posted the compounds. It should work for 2.7.1.1 and up
https://forums.autodesk.com/t5/forums/forumtopicprintpage/board-id/6060/message-id/8558/
Message 131 of 143
hagenobin8
Hello Bruce, a little late to the party. But where do I place the file in??
Message 133 of 143
ID22OX22
Hey Bruce.
I'm having a problem with the lightning simulation.
It seems some nodes are missing.
I think there are 8 missing, but everything is so complex I can't identify it.
I know I downloaded all the required files. Your files and Rebel Pack 0.3.0.
Do you need more information?
I could really use the help. I really want to use your lightning.
It'll be a perfect upgrade for my elemental characters.
Message 134 of 143
ID22OX22
I have this exact same problem.
I can't figure out how to fix it. Do I need to make modifications or download more files?
Message 135 of 143
sepu6
Message 136 of 143
vmohdasad
Community Visitor
Community Visitor
Hi, when i hit tab into the bifrost graph editor i dont see the bruce written in it, please help me out.
Message 137 of 143
vmohdasad
Community Visitor
Community Visitor
Message 138 of 143
sepu6
did you put the compounds here? and if so can you show how the directory looks like.
https://help.autodesk.com/view/MAYAUL/2025/ENU/?guid=Bifrost_Common_install_compounds_and_graphs_htm...
Message 139 of 143
eduardo_riveraP6GC5
Community Visitor
Community Visitor
como instalo la herramienta?
muchas gracias
Message 140 of 143
gerarmanuel31
Observer
Observer
Is there a way to update these nodes or effects? The nodes were created in Bifrost version 2.1, and now it's at version 2.6. I've reviewed your script, and it has changed a bit.
