This could happen with the latest macOS Ventura update.
There are known compatibility issues between AutoCAD / AutoCAD LT and the latest macOS 13 Ventura update which affect the command line.
The recently released Autodesk updates described in this article provide a fix -
https://knowledge.autodesk.com/community/article/420061
What to do -
install the Autodesk updates mentioned in the article. You can get it on your Autodesk Account here
https://manage.autodesk.com/
For more information, look at this article:
Labels:
3 Comments
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
