Is it just my imagination or can we really not override the graphics of wall Parts? I've tried everything - Object Styles, VG, Filters, right click and override graphics per object - can't for the life of me get a black line to go around the parts. Do I really REALLY have to use the Linework tool for this?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Show Both under Parts Visibility in View Properties.
...if need be, set Wall Category Detail Level to Coarse under VGOs.
BTW: Hi.
'Both' does things I don't want - brings back the pink poche which we REALLY do not want to see on the detail view and also does weird things to the sketch edit that has been made.
Pink Poche from Coarse Fill? Can't you Override that? Under VGOs. Cut Pattern off.
...is this the look you are going for?
The pink is gone - however the sketch turns weird.
This is what I want -
VS this is what I get when I see BOTH -
Yep. Been there done that. Just thought there may be a more elegant solution.....
Thank you! Good to hear from you after such a long time!!!
