what i am wanting to do is connect pipes at an angle - maybe 3° max. but make the pipes actually connect with a gasket - currently it shows them leaking and doesn't insert a gasket
I am using the UK DI pack and trying to connect push fit socket spigot pipework see below
![pipe not connecting.png pipe not connecting.png](https://forums.autodesk.com/t5/image/serverpage/image-id/551105iCB8AE908741385D3/image-size/large?v=v2&px=999)
the pieces pipework on the left are connected (but not) at a slight angle to each other
the ones on the right are joined straight - this produces a gasket and doesn't show the pipes leaking
i understand on other specs you would be able to use the cutback elbow or whatever to trim a bend but this wont work for this type of pipework.
is there a way to get these to connect properly?
cheers
