issue- Software using gasket from "PlaceHolder Imperial" spec while I am working in CS150 spec.
-I am using CS150 in built spec.
-Before in BOM gasket was coming as " Imperial part" as description.
-I removed Imperial spec from project as I already have spec CS150 with all size gaskets available.
Still I am facing the attached error.
(FYI-All settings are default nothing has been changed. I have tried using other spec CS300 etc. but same error )
Please suggest any solution to this issue.
