AutoCAD Plant 3D Forum
Routing pipes at angles
1 REPLY 1
557 Views, 1 Reply
what i am wanting to do is connect pipes at an angle - maybe 3° max. but make the pipes actually connect with a gasket - currently it shows them leaking and doesn't insert a gasket
I am using the UK DI pack and trying to connect push fit socket spigot pipework see below
the pieces pipework on the left are connected (but not) at a slight angle to each other
the ones on the right are joined straight - this produces a gasket and doesn't show the pipes leaking
i understand on other specs you would be able to use the cutback elbow or whatever to trim a bend  but this wont work for this type of pipework.
is there a way to get these to connect properly?
cheers
1 REPLY 1
h_eger
Dear @Anonymous,
you can change these settings via the DefaultConnectorsConfig.xml.
http://www.pdoteam.com/2015/04/using-tolerances-in-plant-3d-2016/
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Technology Administrators
AutoCAD Beta
