AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to indicate sloping lines with a triangle not a sloping arrow on Iso drawing
2 REPLIES 2
malcolm.bale
776 Views, 2 Replies
Seems so simple but I can't find the setting.
I want the Piping Isometrics to show the Line slope as a Triangle together with the Ratio and not a downwards pointing arrow. I've tried the various Selections in the Iso Set-up but cannot seem to make the Triangle show.
See images attached
fall.PNG is what I want but fall1.PNG is what i'm getting
2 REPLIES 2
jw7018
in reply to: malcolm.bale
We add an ISO Note & manual drop a triangle block into req'd sloped ISOs.
Hi Malcolm,
You can change the isoconfig.xml file to use the slope triangle instead of what you have set.
Open the isoconfig.xml for the iso template you are using in a text editor and search for <SlopeSymbols>.
By the looks of the screenshot you are using ratio so change the Key="Ratio" line to the following.
      <Item Key="Ratio" Value="AnnoSlopeTriangle" /> <!--"AnnoSlopeRatio" />-->
The last bit '<!--"AnnoSlopeRatio" />-->' is just commenting out what the field used to be incase you want to change it back.
Save the file and run an iso and it should be a slope triangle instead.
Technology Administrators
