Rectangle/Box around PART/ITEM Number in isometrics are not equal for all as shown in attached image.
For Pipe Component it is perfect, but for other component it is squeezed, when I select Scale enclosers to fit text, if the same is not selected then for F G B group it is not showing perfect BOX.
Is there any way around for this?
Thanks in advance,
Solved by Ray_K. Go to Solution.
Try changing Flange Group AnnotationStyle to "SRectangle"
<GroupScheme Name="FlangeGroup" AnnotationStyle="SRectangle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false">
I have escalated the problem with Autodesk under CaseNo:22187134.
I hope Autodesk can fix this little bug after 3 years.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Any time you make changes in the project setup you must hit APPLY for the changes to take affect. Just hitting OK does not save them.
