AutoCAD Plant 3D Forum
Part/Item Number Box in Isometric...
6 REPLIES 6
janakkpandya
489 Views, 6 Replies
Rectangle/Box around PART/ITEM Number in isometrics are not equal for all as shown in attached image.
For Pipe Component it is perfect, but for other component it is squeezed, when I select Scale enclosers to fit text, if the same is not selected then for F G B group it is not showing perfect BOX.
Is there any way around for this?
Thanks in advance,
6 REPLIES 6
Ray_K
in reply to: janakkpandya
Try changing  Flange Group AnnotationStyle to "SRectangle"
<GroupScheme Name="FlangeGroup" AnnotationStyle="SRectangle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false">
h_eger
@janakkpandya ,
I have escalated the problem with Autodesk under CaseNo:22187134.
I hope Autodesk can fix this little bug after 3 years.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
janakkpandya
in reply to: Ray_K
This worked, but the only thing is worried is if we do any changes in Project Setup within Plant3D, it changes back to Rectangle, in this case every time after saving setup from Plant 3D need to do this manually in .xml.
Thanks.
janakkpandya
in reply to: h_eger
OMG...
km4504
Any time you make changes in the project setup you must hit APPLY for the changes to take affect. Just hitting OK does not save them.
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
David_Peek
in reply to: h_eger
Danke Hartmut, das ist ein echtes Problem.
