I have a rather silly problem. The command line expands slightly every time I open and close Plant 3D.
![GarrettBrothers_1-1653502846257.png GarrettBrothers_1-1653502846257.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1071962iE059A97448B4FC07/image-size/medium?v=v2&px=400)
What the command line should normally look like
![GarrettBrothers_0-1653502814265.png GarrettBrothers_0-1653502814265.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1071960i56B2BBDDBE6C6645/image-size/medium?v=v2&px=400)
What the command line eventually looks like
I notice that when I first open Plant 3D, the software covers all of the screen, including my taskbar (which I have pinned to the right side of the screen). After opening a drawing, however, Plant 3D resizes to the proper size. I believe the command line expands when Plant resizes.
![GarrettBrothers_3-1653504416940.png GarrettBrothers_3-1653504416940.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1071975i953090A5023995A0/image-size/medium?v=v2&px=400)
Plant 3D covers the entire screen.
![GarrettBrothers_2-1653504123633.png GarrettBrothers_2-1653504123633.png](https://forums.autodesk.com/t5/image/serverpage/image-id/1071971iF291FF7C370EBED2/image-size/medium?v=v2&px=400)
The proper size
This isn't a huge bother. I suppose it might be a problem if I let the command line expand so far that I couldn't collapse it back to normal using the grips :P, but the issue is probably so deep in base AutoCAD that the dev team wouldn't be able to fix it.
