AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Command line keeps expanding
0 REPLIES 0
Message 1 of 1
Garrett.Brothers
180 Views, 0 Replies
I have a rather silly problem.  The command line expands slightly every time I open and close Plant 3D.
What the command line should normally look like
What the command line eventually looks like
I notice that when I first open Plant 3D, the software covers all of the screen, including my taskbar (which I have pinned to the right side of the screen).  After opening a drawing, however, Plant 3D resizes to the proper size.  I believe the command line expands when Plant resizes.
Plant 3D covers the entire screen.
The proper size
This isn't a huge bother.  I suppose it might be a problem if I let the command line expand so far that I couldn't collapse it back to normal using the grips :P, but the issue is probably so deep in base AutoCAD that the dev team wouldn't be able to fix it.
0 REPLIES 0
